I'm curious if anyone has seen this before. I was out on a really rough road for about an hour-the kind of road that just vibrates everything, even aired down a bit it was rugged. On the way back i was getting voltage faults from my Alternator charger. The battery was diving and there was no power coming from the alternator. I had a backup battery system that allowed me to get to civilization but ultimately that gave out as the warning lights were going nuts and losing power steering. Finally had to have it towed to Ford, Roadside assistance was worthless so they said I could find my own Tow and they'll reimburse me. I assumed the alternator died and while waiting read up on alternator chargers not being completely safe-if you use a DC-DC charger you should familiarize yourself with the do's and don's of those systems. My assumption on the alternator was because I could start the engine but it dies instantly when I remove the negative terminal from the battery.
Anyway, The dealer told me two days later it was a cracked buss bar, probably from rough roads. There was no burn signature from reversed polarity on a jump start which is how these usually blow. The excuse for it happening being rough roads was concerning, pretty sure that's the whole point of the Raptor. Additionally, when doing research I found a vendor that makes a heavy duty version of the Buss bar. Seems it should be heavy duty from the factory.
Has anyone else had this issue or even heard of it? I'm getting a backup part since I get out to nowhere and don't want to be stranded.
