Your aftermarket wheels need to be specifically for a "Bronco Raptor" or "F-150 Raptor". F-150 17" or larger wheels may also work but confirm before purchasing.
It may be possible to install an aftermarket "Bronco" wheel onto your "Bronco Raptor", but do NOT. You may very well break the wheel studs. The aftermarket bronco wheel may fit flush against the hub but upon tightening the lug nuts there will be a bending moment placed onto the stud resulting in breakage... at some point.
6 x 135mm bolt pattern, 87.1 mm center bore/hub bore, M14 x 1.5 stud thread size, 150 ft/lbs lug nut torque.
Bronco
6 x 139.7mm bolt pattern, 93.1 mm center bore/hub bore, M12 x 1.5 stud thread size, 100 ft/lbs lug nut torque.
Bronco
