Correct Speedo Error For Oversize Tires Using Forscan
timhutch
Southern California
Hi all, I know there are a lot of posts about how to use Forscan to correct speedometer error after installing oversize tires. But I've just gone through the process with my 2023 BRaptor and thought I'd share some info that I couldn't find in other places. First off, I went to 39" BFG KM3 Mud Terrain tires, adding about 2" in tire height. Actual, measured tire height is about 38.5" verses the 36.5" for the OEM KO2's. This change caused about a 4mph speedo error at 70mph (indicating 70 going 74). Not super happy about this as I felt I would be more likely to get a speeding ticket, it messed with mpg and range remaining data showing less range and mpg than actual, odometer was no longer accurate (fewer miles indicated than actual) and finally, it seemed to be effecting the transmission shift points. For all these reasons I decided to attempt to correct the speedometer error with Forscan.
I used Forscan release 2.3.63 to make the changes and it was very easy. There are a lot of You tube videos showing how to do this. What is more difficult to find is the correct value for the new tire sizes. There is a formula that appears to work properly that goes like this. Get your tire circumference (mine was 122.5") convert to millimeters (3111.5mm) and apply a multiplier value to reduce/scale the size value. Internet said .967 my calculations put it at more like .933 based upon the stock/default tire circumference value programmed into the truck and the OEM 37" tires. So applying the multiplier we get a new value to be written of 2903 (3111.5 x .933 = 2903) verses the stock value of 2753 (2951 x .933 = 2753). But you will find that when you go to write that value (2903) into the BCM that the relearn required on the PCM module fails with a "tire size value out of bounds" error. Through trial and error I discovered that the max value allowed in the BCM module for tire circumference is 2885. It appears that this value would be correct for 38" tires but it's really very close for the 39" KM3 tires (which are actually more like 38.5").
My speedometer error at 65 is now about .8 miles per hour (indicating 65 going 65.8) and has returned my odometer and mpg/range values to be much more accurate. If I decide to increase tire sizes above what I have now it will probably require something like the Hypertech Speedometer Calibrator that remains installed on the vehicle. Hope you find this useful!
I just put 40" tires on mine this weekend and I tried getting Forscan to program for that circumference but ran into the same issue. I'll see if it'll take the 2885 but right now I still have the service 4x4 light on even though I put the number back to what the stock setting was and did a relearn. Since I likely can't get Forscan to do what I want I'll probably have to buy the Hypertech. I used that on my F250 and it worked great.
Did you do the PCM and AWD module relearns? You will need to do the relearn on both of those modules after changing the tire circumference to clear the service light.
Yes I did both more than once and cleared the DTCs but hasn't cleared it. Will try again this evening.
Confirmed the maximum number it would accept without an error is 2880. Relearned PCM, AWD, and cleared DTCs. All clear now.
Thank you for this post! I also put 39" KO3's(AT) on mine and couldn't get the ECU to not be upset about it. I spent a couple of hours trying PCM and AWD resets in different orders and even put my Procal tune back to stock and started from scratch. Kept seeing the error message about tire diameter being out of range(I had it set to 3077). Found your post and plugged in 2885, relearned AWD and PCM, cleared DTCs and it seems happy with that. I haven't driven it yet but the ABS and Advanctrac errors have disappeared when the ignition is turned on. I reflashed the ECU with my procal tune and still no errors of warning lights(fingers crossed)
On a side note, I looked for a Hypertech Speedometer Calibrator for the Braptor, but their website doesn't show one. I think i can live with the 1 or 2 MPH off at 75MPH; which incidentally will get more accurate as the tires wear :-) Driver's side tire rubs a little at full lock, but i'm hoping wheel spacers will sort that out. I already have a 2" lift in the front so hopefully a 1.5" offset on the wheels will do the trick.
I also have about a 2" lift in the front (courtesy of Eibach springs) and also had a minor rubbing problem at full lock (mostly when backing up). I found that removing the small plastic/rubber trim at the rear edge of the front bumper fixed this problem for me.
I'll give that a shot and see how it goes. I'll update this post on the wheel spacers if they also make a difference.
