EZ4X4 hardtop lift
Motorpig
Vegas
2024 Bronco Raptor
2022 F250 Tremor
Retired LE
Bought this and it works great. Had to put it together, but even that was easy enough. Just time consuming. Stores folded up nicely, too. The ease of taking off the rear top by yourself and no drama is priceless. Under 10 minutes, screwing around, to remove now. I give it two thumbs up👍🏼👍🏼
Anyone running their EZ hinged top kit for 4 door?
I have been thinking about getting one.
It works with 2 door Bronco, too.
I have seen a couple versions. This looks to be the winner for me. I have a pretty packed garage and I like the way this folds up when not in use (Winter time).
Looks great, what roof rack are you sporting there?
That's the EZ 4x4 middle panel holder roof rack. It's built to allow you to slide and lock in place the middle roof panel (with the front panels if you install the flip-top kit). It's very cool. Also the Turn Overroad side molle panel kit fit right on with a little giggle (read no cutting or drilling or losing my mind even if it was done well after sundown).
Chatted with their CS on their actual website and the 2dr lift will work on either. They do not recommend that you use the 4 dr lift on the two door top. I didn't get a clear answer as to why (Actually didn't bother to ask) but I suspect that the stabilizer leg that folds up at the base on the 4 dr might be shorter in length since the 4 dr top is shorter than a 2 dr top.
(https://www.ez4x4.com/collections/e...AZiWNbJh3gdHhwm8OaB7HGjaknduIYqxoCYyIQAvD_BwE)
Hmmm, the 2 door lift looks a lot different. Wonder if it's a newer design. Good to know and my apologies.
Good luck with new braptor and purchase the Ford 3.0 Ford tune, Can I buy that black 4 door Ford pick up in the pic ? That's nice, I would luv that :)
