Ape Factory
- Jan 21, 2025
- San Antonio
- Bronco Raptor
I swapped IC's yesterday but didn't get a good chance to get a detailed look at the front active shutter setup. After testing it out yesterday and having highway cruise temps exactly the same as OEM, I had planned on removing the shutters next weekend. Ultimately, I don't think that's a good plan as there's ducting directing airflow to, and not around, the IC core.
Anyone know what the default position is on the shutters if I were to just disconnect the motor? I'm assuming it's open as it just makes more sense from a motor failure standpoint as well as the fact that when the car is off, the shutters are open. If so, I could leave the shutters in place to help direct airflow. Thoughts? I know TurboS used some ABS sheets and molded ducting to better seal the Whipple IC core but not sure I have the time to do all that right now.
