King Coilvers for the Bronco Raptor
Tye
Bay Area
Porsche GT3
Finally some options becoming available. Pictures in the install PDF's found in the following links. Easy bolt-on installation for stock height or custom kits for trucks running lifted aftermarket suspensions.
Front Features include:
  • 100% bolt on performance.
  • Adjustable Ride Height.
  • Large 3.0 diameter shock bodies increase fluid capacity for smoother, cooler running shocks.
  • King's 3.0 IBP Internal Bypass coilover shock delivers precisely tunable velocity sensitive and position sensitive damping as well as a hydraulic bump stop all in a bolt-on monotube shock.
  • King's monotube design uses a full diameter piston and standard, full size valving.
  • Built from the same quality materials and to the same precise tolerances as
    King's top of the line Pure Race series shocks.
  • Bronco Raptor coilovers use large 3/4" top bearings and 1" lower bearings for superior strength.
  • Factory tuned for optimal ride quality.
  • Extensive dynamometer lab testing and punishing real world testing to develop optimal damping curves and spring rates for your Bronco Raptor.
  • Fully rebuildable, serviceable and tunable.
  • Standard Option: Finned Reservoir With Compression Adjuster
  • 3.5" OD Pure Race Series External finned reservoirs dramatically increase fluid capacity, heat dissipation and provide sustained damping performance even under the most punishing conditions.
  • All new threaded end cap design with new Schrader valve protective cap.
  • Made from extruded 6061-6 aluminum.
  • New improved reservoir mounts. No more hose clamps!
  • New hose attachment at the reservoir allows swivel adjustment of the hose clocking.
Rear Features include:
  • Dual rate spring system allows users to fine tune and optimize their suspension setup.
