- May 25, 2022
- Sacramento/Tahoe
- 2022 Bronco Raptor
- Current Ride #2
A while back I installed Hypercoil 1”/2” springs, Foutz top hats and 38s. The ride was noticeably stiffer, but I marked it down to new springs, sturdier sidewalls etc. I got used to it. Then I drive a friends stock Raptor and I realized the difference. It couldn’t be right.
My truck reacted harshly to small bumps and potholes in otherwise smooth rides. Seemed okay off-road, but very noticeable on road.
About that time I saw a post somewhere on whether ride height needed to be recalibrated after a lift or not. Learned separately how to check the ride height and recalibrate the VDM module in Forscan.
Sadly I forgot to check the ride height measurements before recalibrating, but the recalibration went smooth. My truck is riding much more like stock again.
In any event, if you’ve done a lift and not done the recalibration you might want to look into it. If you’re Forscan capable it’s a very quick service procedure.
