- May 25, 2022
- Sacramento/Tahoe
- 2022 Bronco Raptor
- Current Ride #2
After making a couple Forscan changes on @Dgchurch truck, he issued a challenge.
He wanted his oil, engine and transmission dial gauges in the digital instrument cluster to display the actual temperatures. Challenge accepted!
Almost no documentation on Broncos for this as only the Raptor had the digital cluster. Searching around F150 and Ranger, led me to some clues and….
It worked! This just requires a simple manual edit to the IPC module “as built” file in Forscan. Directions:
Enter IPC module as built file and locate block “720-07-01”
Note: When I pressed “Write” Forscan gave me a “check digit” dialog box and I pressed “continue” to write the change.
After writing the change(s), the cluster resets and you will see the change in the cluster. .
Before:
After
Ranger Forscan Spreadsheet for more detail
- To update Engine and Tranny Temp gauges, change to xxxx-xx5x-xx—. This changes ETD and TTD from SP1 (A) to Always on (5).
- To update the Engine Oil Temp gauge, change to xxxx-xxx4-xx—. This changes EOD and TTD from SP1 (8) to Always on (4)
Before:
After
