I thought it would be nice to have a hook in the back of the Bronco for dry cleaning, jackets, hats, gear, etc. So, I decided to make one! Here is my V1 Gear Hook for the Ford Bronco that uses a pre-existing threaded hole on the back roll bar. There is a hole on each side of the roll bar so I will be including a pair of hooks along with mounting bolts. The hooks are made of High-Modulus Carbon Fiber for extra strength and durability. It also has a nice MIC (Moded In Color) look to it. The mounting bolt in the pictures below is for testing only. The final bolts will be pan head Torx bolts and I hope to have those in soon. Let me know if anyone is interested in a set of hooks for the Bronco!
*Make sure your Bronco has the threaded mounting holes in the roll bar because not all Broncos do. Ford changed this sometime in mid-September production.*
www.etsy.com
Ford Bronco Roll Bar Gear Hooks Only Fits 4-door Broncos With Roll Bar Mounts Lifetime Warranty - Etsy
This Car Accessories item by SinisterSpeedShop has 286 favorites from Etsy shoppers. Ships from Fredericksburg, TX. Listed on Aug 19, 2024
