- May 25, 2022
- 498
- 1,199
- 2022 Bronco Raptor
- Current Ride #2
So I’m getting new rims to minimize the possibility of future debeading incidents and to allow lower air pressures.
I purposely went with base rims when I ordered because I liked the look the best and wasn’t convinced that I would really use the beadlock capability. I figured the $2800 I saved from not getting the option and the additional beadlock rings would go a long way to paying for rims I like and the functionality I want. Selling or keeping my base rims is icing on the cake.
So in researching beadlocks (BL) and bead grip (Method,Icon) (BG) rims I’ve discovered that there aren’t many choices in a 17” 6x135 8.5-9” and there aren’t ANY with an offset over +6 other than Ford OEM rims. Im not thrilled by the increase in width, but I’m left with no choice in the matter.
I’ve never been a big fan of BL rims, due to cost, weight, maintenance and compliance issues. So I’ve gravitated toward BG rims. Basically down to Method 105 with 0 offset or Icon Rebound Pro with +6
I think I’m settled on the Icon Rebound Pros due to the simple look, ease to clean, and seemingly stronger bead retention approach than Method. Thinking satin black, so I can touch up rock scrapes from time to time to make them more presentable at first glance. At 32 lbs they’re probably way lighter than any beadlock by a pretty wide margin.
So, building on the fact I’ll have an extra inch of offset, I’m now thinking about going with a little bigger tire, probably 38”. 38” feels like the right balance of being a little bigger, minimal extra weight, minimal extra stress on the steering, and will require minimal lift (I’m guessing I won’t get away with no lift)
So assuming I’ll need some lift I was thinking Foutz collars, 1.5” upfront and 1” in rear to give a little more room, a little more level (especially with winch/plate installed) but minimal tweaking of suspension
Since there is a lot of experience and knowledge out there I thought I’d ask you guys….My questions to the forum are:
- Am I missing a good rim option option that has more positive offset?
- Does my proposed 17”x8.5” +6 Icon Beadgrip wheel, 38”x12.5” tire and 1.5’/1” collars make sense? please Share your thoughts!
