10 Hidden Features of the NEW Ford Bronco! - By TCcustoms
TurboS50
9 minute video covering 10 Bronco model specific features.
"Hidden features of the all new Ford Bronco! Starting off with the first hidden feature, did you know that now the windows crack a little bit when you unlock your vehicle. This helps with the window being floppy. The second thing is that exclusively with the new Bronco Raptor, for 2024 the fender flares now come with paint matched with the vehicle. The third thing is for 2024 there will be a late availability option where Ford will do paint to match hardtops. Next is the updated soft top. Ford updated the soft top to help with rain getting on you when opening your Bronco door. Another massive update is that the Badlands gets the HOSS 3.0 Steering gear. Next up is the 12 inch infotainment system. This will now be on ALL trim levels, not just the higher trims. The next feature is that if you want a trailer tow package, it will have to be dealer installed. Good news is that the Broncos now have X-Plan pricing! This includes all Broncos excluding the Raptor. The final thing you need to know is your availability to go to the Bronco Offrodeo. Your time expires by the end of 2024 so we highly recommend you check it out while you still can!"
Below is the first video that is referenced above with Bronco specific features recorded a couple years ago.
"Today I'm going over hidden features I bet you didn't know about the 2021 Bronco!
1. No matter what package you have, your Ford is equipped with global windows. This means that if you tap and then hold down the "unlock button" on your key fob, it will roll down the windows.
2. The range on the key fob is further the higher trim level you have.
3. If you are out of range of the hey fob, put it under your chin and your head will act as an antenna that will extend the range.
4. If your key fob dies, take out the battery. Then insert the key into the indention in the bottom of the center console and push button start will work again.
5. If your vehicle does not have auxiliary switches, there is a pocket for your sunglasses in the roof.
6. Even if your vehicle does not have remote start, you can download the Ford Pass app and start your vehicle from your phone as long as you have an internet connection.
7. The QR code on the windshield is the production date which is used for the manufacturing process.
8. If you forget to tighten the door bolts enough, the Bronco will warn you by making a clicking sound when trying to close the door. "
