This set of gear hooks is exclusively designed for the 2021+ full-size Ford Bronco! These gear hooks are made with a High-Modulus Carbon Fiber filament that not only looks great but is also as rugged as the vehicle they are bolted to! Since the Bronco does not come equipped with a garment hook typically found in most vehicles, these custom-made hooks bolt directly to pre-existing holes on the rear roll bar of the Bronco and provide an easy way to hang your dry cleaning, jackets, hats, bags, backpacks, etc.
This set of hooks is designed to fit all full-size Broncos that have speakers mounted to the rear roll bar. Just remove the lower speaker mounting bolt with a T30 Torx bit, install the Gear Hook and screw the bolt back in. Repeat the process on the other side and you're done!
2021 Ford Bronco Gear Hooks Cargo Area Speaker Mount Fits Any 2-door and 4-door Bronco Lifetime Warranty - Etsy
This Car Accessories item by SinisterSpeedShop has 875 favorites from Etsy shoppers. Ships from Fredericksburg, TX. Listed on Mar 28, 2024
www.etsy.com
