For any members with non-Raptor 4 door Broncos, the mid flaps fit and install the same way as the Bronco Raptors. Both platforms use the same body mounts, which have the same oem mounting holes. The only difference is the 4 door Broncos use a different rear control arm set-up that are shorter, too. The mid flaps will hang a little lower as the front lower control arms have a different frame mount. I waited to sell to the 4 door Broncos because I wanted to test them in the rocks crawling. They help up so far without issues.
Protection: For oem Bilsteins or upgraded Fox's, they will help with only the upper half of the shocks. Both use upper shock boots, which do the job. Where the mid flaps help significantly are for the aftermarket shocks. Most do not use shock boots to protect the shock shafts, so the mid flaps will do that job now. Also, some aftermarket shocks have remote reservoirs placed similarly to the Bronco Raptor, which are high, and the mid flaps help.
2 door Broncos: I am now in the process of making sure the mid flaps fit properly. They do have the same body mounts and oem holes for mounting. I will report back when testing is completed. I'm pretty sure they will function exactly the same as the 4 doors.
Again, thank you for those that purchased and for the support!
