Advanced Fiberglass Concepts Bronco Raptor fenders
"This concept isn’t exactly new, as ADV already makes and sells these same wide fiberglass fenders for the regular Ford Bronco – which appeared on Baja Forge’s 2021 SEMA Show concept – as well as fiberglass hardtops as an alternative to the OEM molded-in color piece. However, it has now added something similar to its catalog for Ford Bronco Raptor customers, too.
These new Bronco Raptor fiberglass fenders are for the front only, though the existing rear units from ADV will fit this particular model, too. Shoppers can choose from two different sizes – a 4.5-inch flare with a one-inch rise, or a 7.5-inch piece, also with a one-inch rise, but either way, these fenders reportedly fit the high-performance off-roader perfectly.
The new ADV Bronco Raptor fenders also allow owners to run a larger tire, which is always a good thing, and come finished in semi-gloss white, which means that buyers will want to paint them before installing them on their rides. Installation is relatively straightforward, though it does require using either a sawzall, plasma cutter, or metal shears, so it might be best to leave that up to a professional. Either way, these new fenders retail for $950 a set, and fit both the 2022 and 2023 Ford Bronco Raptor, though they aren’t expected to ship until June and July, respectively."
By Brett Foote
Source: original article on Ford Authority.
www.advfiberglass.com
By Brett Foote
2022-2023 Ford Bronco Raptor Fenders
Upgrade your Ford Bronco with a set of flared fiberglass fenders from ADV Fiberglass! These hand-laid fenders are designed for a seamless transition.
2022-2023 Ford Bronco Raptor Rear Quarter Kit
Upgrade your Ford Bronco Raptor with a flared rear quarter panel kit from ADV Fiberglass. This kit comes standard in semi-gloss white and bolts onto your Bronco.
