Any charge pipes for our Braptors?
CRAZYACE63
2023 CO Braptor
I've seen that the Ranger Raptor has a few different companies making charge pipes for it. Since we have the same size motor do you think that any company will be making some for us? Thinking aluminum pipes would dissipate the heat a little more for cooler intake temps.
Any info would be appreciated.
I've been wondering this as well. I'd love to knock this out with a IC upgrade and intake at the same time.
loop me in also, Interested in this.
K&N Charge Pipes
This seems to be all that's out there which is kinda crazy to me. I'm guessing this replaces just the piping from the single side of the IC to the throttle body?
Wouldn't a Carbon Fiber material be better?
Aluminum will draw in and retain the ambient heat. This will transfer the btu's via convection to the incoming charge air. I understand that the velocity of the charge air will make it a short time exposed to the btu's, but why change a warrantied part for something that is only going to change the issue to another issue. Hold out for a solution.
Or better yet, design and manufacture the solution.
Unfortunately, those are not compatible with MY24. Following this to stay up to date with new options.
I did Email S&B. They made my cold air intake. As of now no plans for Charge Pipes from them.
Why? As far as I know, the only difference between the 23 and 24 is a few added wheel packages and colors. Anything made for a 23 would fit the 24.
I second that - everything I see says compatible with my24
Just their website doesn't show support for 2024. I emailed them to ask if it just needed to be updated or if there is a real incompatibility. They have not responded yet.
This is what xtremeterrain says - maybe ask them if K&N isn't responding.
So, I know it's been awhile since I was on the forums. I reached out to BuckleupButtercup since she was tuning and upgrading her new Ranger Raptor. She said that she will do some testing with the charge pipes they have in stock for the ranger and see if they fit the Bronco. Fingers crossed that these work since it is the same engine.
K&N finally responded:
I followed up and asked them:
Are these compatible with the 2024 Bronco Raptor? The K&N website says no, but other sites and forums say yes.
They responded:
Unfortunately the 77-1020KC only fits the 23 Bronco Raptor and the 24 Ranger Raptor.
They responded:
Check out the Process West above in the thread. I know Kristine has them installed on a Bronco Raptor.
That red kit (out of stock) looks sick! It does not list any HP or other gains. Have you seen any numbers posted? I like the compatibility.
AFE has a full set of pipes for the Bronco Raptor as well.
I have not purchased any Intercooler / Pipes yet. Still deciding on which set?
I have the Ford Performance Pro Cal ready to Install. But I want to do all at once with a CAI as well.
Let us know how the install goes..
