Anyone tried to modify a factory soft top to work on a raptor?
Solo
23
13
Greenbottom, WV
US Army (ret)
01 lightning, 77 Bronco
08 King Ranch F150, 16 Wrangler
Just as the title says.
S
Solo
23
13
Greenbottom, WV
US Army (ret)
  • #2
Anyone have any input. The bestop trektop is a no go. It is a permanent replace t. Lots of brackets and seals that neet to be stuck on. No way to put the hardtop back on if you want. So im thinkin with a little modification to the top bracketry, the factory top will work. Any thoughts?
3,376
Just as caution, the Raptor specific additional B and C Pillar braces are to Not be removed or modified including the outside plastic trim on the braces according to the owners manual.
S
Solo
23
13
Greenbottom, WV
US Army (ret)
  • #4
Yep. Got it. Was talkin about modifying the soft top brackets to fit around what is there already.
DdYHrse
255
381
Dallas, TX
Whoops. I took the two bolts out of mine on the driver side rear bracket and mounted a fire extinguisher. I did put them right back where they were, but with dealerships these days you never know. Ha.
3,376
Those braces are doing a lot of work to stiffen the body by 50%, there is probably a torque spec on them that's not available to us yet.
