Bronco Raptor Crash!
Keep it. Any hit on market value has already been taken. The damage sounds pretty minor and very easy to fix. Pics??
Not bad. Fix the tie rods, run the Rubicon, then get the body work, wheel and lighting repaired. This is an opportunity! 🤪
Just picked up a used Raptor, and someone crashed into me the first day... 8k miles, would you keep this beast after repairs?
1.New Metal Bumper (Small dent)
2.New LED Light (Small Crack)
3.New Tie Rods (Due to bend from Impact)
Minor repairs compared the other guy (Totaled)
I just had to replace a tie rod and could not find OEM. I found a set at Foutz Motorsports which are a little pricey but much better than OEM. I’m with the others, you damage is minor. Definitely repair.
Check the transmission mounts and engine mounts jic
Yours has minor damage and his was totaled?
