BRONCO RAPTOR PORTAL AXLES | what should we do? - by 74Weld
TurboS112
18 minute discussion of challenges and constraints with Bronco Raptor Portal Axle design, and Quinn is asking for your input on some of the design decisions. I recommend when responding to Quinn's questions, after listening to his entire video, that you comment directly on his YouTube video comments section. Of course we also welcome your concerns and discussion here on this thread. This is your opportunity to have input into the development of Portals for our Bronco Raptors.
"WE SAID WE WOULD NEVER DO IT, BUT THEN FORD CALLED.
Now we don't know what to do. We need you to tell us."
"By now most of you have seen the Mega Bronco, the SEMA build we did with Ford Racing: a Bronco Raptor on 74Weld portals, powered by a 1,200 hp supercharged 7.3L. After a lot of comments asking whether we’re making a bolt-on Bronco Raptor kit, Quinn goes through how the build came together, what it would take to turn it into a product you can buy, and the decisions we want your input on."
What’s covered:
  • How the Mega Bronco was built: a Bronco Raptor platform, a Wilwood front brake package, and a Kincer-built Dana 60 rear with Bronco Raptor brackets.
  • Track width: the Bronco Raptor starts at 87" outside of tire. With a +60 offset 18" wheel, the Mega Bronco came in at 92".
  • Why outside-of-tire width is the only portal width number that matters.
  • Tire size and lift: 37s from the factory, 42s on the SEMA build, and whether 40s make more sense.
  • ABS compatibility: the Raptor-specific tone ring and how we kept full ABS function.
  • Why a Bronco Raptor portal kit needs an aftermarket outer CV (the factory IWE locking collar won’t work).
  • Rear portal backer plate and caliper bracket plans.
  • The big question: 6x135, 6x5.5, or 6x6.5 bolt pattern?"
"We want your input. We already have a 6x6.5 bearing pack with full Bronco Raptor ABS compatibility. Would a 6x6.5 wheel be a deal breaker for you? Is 92"+ outside of tire too wide? Tell us in the comments." (YouTube video comments section)
"Interested in portals for your build? Check out 74weld.com"
"74Weld designs, machines, and assembles portal axle systems in Southern California.
Performance Without Compromise."
