Scuba Steve
- Jul 6, 2026
- California
- Military
- Coast Guard / Machinery Tech
- 2025 Bronco Raptor
- Current Ride #2
- 1968 Bronco
Here is a project I just finished
My goal was to find a place to mount the ARB twin Brushless compressor. I tried the AGS off-road spare tire mount. It Doesn't Fit!. Returned it and had to pay shipping because their website sucks and so does their customer service.
I then found the DV8 Storage Compartment (not the one for a dual compressor). I wanted the blank box so I could mount my items easier. Also I didn't like the ventilation holes In the bottom of the box in case of water crossings.
I installed a 120 amp circuit breaker and fabricated a mount from the existing battery box. I ran 4 gauge wire with protective loom all the way to the rear storage compartment and connected to the box via a Bulkhead fitting studs
The ARB twin brushless compressor is pretty big. I had to fabricate a mount so the compressor was slightly angled. I also fabricated a bracket for the Midland MXT575 GMRS radio to mount
I simplified the ARB compressor wiring and used the up fitter switch to energize. The Midland is powered from the fuse block and energized by the up fitter switch through a relay. I installed carpet using the OEM floor mat as a template. The Bronco Tool Box will cover most of it anyway.
Installed "chaffing" protection on all wires entering the box
I also purchased the Ecoflow 800 watt alternator charger. I wired it to the bulkhead connectors in the box instead of pulling wire all the way to the front of the vehicle.
I mounted a Air connector bulkhead fitting to the tool box and routed the air line through the box with a large grommet down to the compressor
After everything was wired up I can slide the drawer back in. I purchased the DFG off-road fridge freezer slide with tilt to mount it on the box.
