Foutz slot delete kit
Turbo yzel
DMV
2022 Braptor
Last week I was able to get part of this installed
I still need to get them welded on
Just wanted to make sure I had them in right spot
Here are some photos for others to use and some tips 👍
Here are some more
I had to loosen one side of the sway bar at a time to get factory bolts out
As you can see it would hit when sliding out
So I swapped the ones in back 180 and put them in reverse
So if I need to do work on the trail it will be a little easier to get to without messing with the sway at again
Also make sure that you put ones with notch cut out in right spot 👍
And finally I tried again for the 3rd time to adjust my positive camber after installing plates
However I am now almost out of adjustment after doing “out of the box” 1st time
Then 1 full turn after billet rack install
And this time 2-1/2 turns with slot delete kit
And I still have a little positive camber
Strangely it still says same amount after each time I adjusted the upper arms 🤷‍♂️
At least it seems to drive a little better after the last 2-1/2 turn session
