Morimoto XB LED Headlights - Install and Overview
LethalJoe
South Florida
12' CTS-V
Hey y'all!
I recently had the chance to play around with Morimoto's XB LED Headlights for the 2021+ Bronco's and, unlike popular opinion, I actually like them!
These are the White DRL version, however they also have an Amber DRL version to keep that Raptor amber DRL style.
The performance of the lights themselves are insane over the stock LED's, thanks to Morimoto's BI-LED design. I honestly didn't think the difference would be this drastic, but you gotta see for yourself. The beam is wider, sharper, and brighter. Not really sure how they're DOT legal, but hey, they are.
The install is easy, but does require some harnesses to be ran from the fuse box and around the radiator shroud to each headlight. Overall though, it's all plug and play, with no actual "wiring" required.
While we didn't install on the BRaptor, these headlights will in-fact fit the BRaptors as well. Morimoto states specifically 2023+, but I do believe it will fit 2022+.
The best part? They're at an insane price right now : $459 SHIPPED!
Grab a set here if while you still can! : https://www.lethalperformance.com/s...-bronco/lighting/headlights?manufacturer=2178
Morimoto also has a newer, differently styled headlight called the XRGB, which maintains a more OE-style design, but slightly darker and with bluetooth RGB function. We will be covering these as well soon, so stay tuned incase those catch your eye more.
If you wanna check out the full install/overview of these headlights, check out my video here:
Can you confirm fitment on the Bronco Raptor? I believe the Raptor headlight cavities are different than those in other Bronco trims. The fenders (not just the fender flares) are also different.
Let me touch base with the team over at Morimoto to confirm. They state on their site that these will fit BRaptor, but appears that their newer XRGB Version may be the only version that fits both regular Bronco & BRaptor.
I'll let you know what I find out shortly.
I just heard back from my Rep. and YES! All of Morimoto's headlights are designed to fit the regular Bronco and the Bronco Raptor, so no matter whether you go with these or the XRGB, they will fit your BRaptor.
With that being said, we may just have to play around and swap our BRaptor ones out for a set of these... :unsure:
Let me know if you have any more questions!
