Need Help
Roblowe
KY
2022 Hummer EV
I am in need of the driver side front and rear wheel well liners (accident) and getting the typical 2 step from ford. If anyone has a set please let me know
Welcome to BroncoRaptor.com 🍻 Ouch, but fixable, hoping someone here chimes in with some leads for you.
I would try Ford Performance customer service: 800 367 3788. About 11 months ago one of the FP test Bronco Raptors lost a rear flare, they might have some extra parts. Not the normal process, but maybe worth a try.
Bummer...but could be worse. Seems like now might be the perfect time to consider some aftermarket fiberglass options
That shows the part but not able to order. I was hopeful someone on here was taking off their flares and would sell the liners
Not yet, but I'm sure someone will as soon as a vendor has some aftermarket flares available... not much help to you now. We have a couple of sponsors on here that may be getting a lead for you. Probably already explored this but since these are the liners, I would look at a repair with all intentions of replacing later with new from Ford. For a temporary repair would seek out a urethane bumper repair shop, I've seen plastic welders, That would get you back on the road sooner. I'm not a body shop expert, just trying of offer what I would be considering.
Try this:
FordPartsOnSale.com
FordParts.com
Part numbers are not consistent across all platforms. Definitely verify via VIN before ordering. The "new" Ford parts catalog is not the easiest to search. As shown here, the new catalog uses a truncated PN (16103). The old catalog uses the full PN (M2DZ16103A or M2DZ-16103-A). Key words are tricky also: wheel well vs fender, liner vs guard, splash vs shield.
At any rate, On Back Order as you have stated. @TurboS probably gave you the best advice.
