- Oct 20, 2022
- South Florida
- 12' CTS-V
Hey all!
Eibach just released their all new Pro-Lift-Kit Performance Lift and Leveling Springs for the 2022 and up Ford Bronco Raptor!
Eibach has released 4 different kits depending on how you want to customize your truck, whether it's just a simple front leveling or an entire lift all the way around, all while utilizing the stock FOX Shocks, Eibach has a configuration for just about anyone. (Unless your looking for CRAZY lift)
The Eibach springs allow for full range of suspension travel without additional stress on bushings and ball-joints and has proven so with hundreds of hours and thousands of cycles in development tests over the past year.
The full Pro Lift Kit will give your truck a 2.6" Lift in the front and 1.1" in the rear, providing not only a nice lift but a bit of a leveling from the stock ride height. Check it out here!
The Front Leveling Springs will do as expected and properly level the front end of the BRaptor about 1" to match the slightly higher stock rear ride height. Check them out here!
They also have both front and rear springs from the Pro Lift Kit available as individual sets, incase you're going something custom.
Check out ALL of the various kits here!
https://www.lethalperformance.com/s...o-raptor/suspension/springs?manufacturer=1016
As always, if you have any questions or need some help with Eibach products, reach out with anyone of us here at Lethal Performance!
- Manufactured using race winning off-road race spring technology
- Developed to provide balanced ride quality, control, and off-road capability
- Finished in Heavy-duty corrosion resistant silver coating
- Compatible with factory FOX Hoss 4.0 shocks
- Made in USA
- Limited Lifetime Warranty
