Garrett Turbos, Ford Performance OEM Turbo manufacture, now has larger/upgrade replacement Turbos for our Bronco Raptor 3.0L
Supports up to 640BHP | 477kW (+18% compressor flow and +6% turbine flow compared to the OEM turbo)
Part Number 926432-5002S"
www.garrettmotion.com
"POWERMAX™ DIRECT FIT PERFORMANCE TURBOCHARGER
2022+ Ford Bronco / Ranger RaptorSupports up to 640BHP | 477kW (+18% compressor flow and +6% turbine flow compared to the OEM turbo)
"Key Product Features:
- Direct-Fit Upgrade for the 2022+ Ford Bronco / Ranger Raptor 3.0L
- Kit part number contains complete LH & RH turbo assemblies with calibrated electric actuators
- Garrett is the OEM turbocharger for this application
- CARB Emissions Certified D-871-4
- Supports up to 640BHP | 477kW (+18% compressor flow and +6% turbine flow compared to the OEM turbo)
- 41mm compressor inducer compared to 38mm on the OEM turbo
- Stainless Steel turbine housing rated up to 950°C
- Fully machined sensor port to monitor turbo shaft speed: use PN 923586-0003 (G-Smart Bluetooth Module / App) or 781328-0003 (street kit w/ gauge) or 781328-0004 (pro kit w/o gauge)"
2022+ Ford Bronco / Ranger Raptor 3.0L – Garrett Motion
POWERMAX™ DIRECT FIT PERFORMANCE TURBOCHARGER 2022+ Ford Bronco / Ranger Raptor Supports up to 640BHP | 477kW (+18% compressor flow and +6% turbine flow compared...
