OEM Rear Differential Cover enhancement project
In July of 2022, 3 months prior to taking delivery of my Bronco Raptor, I ordered a OEM rear aluminum differential cover from Ford anticipating I would finish the rough casting and have powder coated similar to what I did with my SuperDuty OEM rear diff cover. It didn't arrive before my Raptor, actually 15 months after I took delivery, 18 months waiting in total.
Pic below of my diff cover as delivered except for painting the "R" in Code Orange.
I used my Dremel tool with a metal cutting wheel to remove the casting risers and other small imperfections. Followed by a file to straighten the rough cuts from the Dremel, then sanded by hand with Emery cloth.
My plan was to have it powder coated in "Super Chrome" with a clear coat which actually looks like polished aluminum as on my SuperDuty as seen in the photo below.
At the last moment I decided to have it done in "Polished Aluminum" rather than Super Chrome. The "R" is done in Prismatic Powders Ford Code Orange PSS-11333. The result isn't what I was expecting, I was hoping for a brighter polished look. I considered paying again to have it redone in Super Chrome but the guys did such a good job I decided to install this cover for this year and next winter I'll do the same process to the now removed original cover and have it finished in Super Chrome powder coat.
The bolts are Marine grade A4-70 (316) stainless steel, ordered from Accu-Components.com. The wiring holders are 1/2" Ancor Marine Stainless Steel cushioned clamps that I enlarged the mounting hole using my dremel with small grinding wheel. I wanted the electical wiring to go around on the outside for maximum exposure of the diff cover.
Reusable gasket.
Mounting bolts torque value is 20NM +25 degrees.
In case your curious to what’s under there:
Added May20, 2024.
As mentioned above, it's a reusable gasket.
And exactly 2 quarts of this synthetic gear lube shown below.
wanted to clarify if we are going to remove the diff cover i'm assuming need to catch all the oil and add new oil when reinstalling ?
Correct, need an oil drain pan under the differential and I prefer to drain after the vehicle has cooled. Loosen the top 2 bolts backing them out approximately 1/8" to be used to hold cover, then remove the remaining 12 bolts, using a large flat head screw driver or small pry tool, gently pry the bottom of the cover away from the differential housing just enough to allow the gear lube to drain while being careful not to harm the reusable rubber gasket. It's gear lube, so its a thick consistency therefore it won't gushing out like motor oil. Once drained, then push cover tight to the housing and remove the upper 2 remaining mounting bolts, then remove the cover.
Sorry this is off topic. Where did you get those exhaust tips and did you have to modify them so they would only peek out?
No problem, those are the Borla exhaust tips, Borla has designed all their Bronco & Bronco Raptor systems like this for higher clearance.
Ah, yes. That would explain it. I love the look. Nice rig and thank you for the response.
I have changed the Diff fluids in 2 of my Broncos. They need fluid a lot earlier than you think. I did mine at 5K miles with lots of Charcoal Gray metal present.
Dana recommends (not Ford) 75w-140 Diff fluids in all their Axles. I would assume it's the same for the Raptor Dana 50 as well. I will do this soon for my Raptor.
At ~2500 miles mine was also Charcoal Gray, I didn't think much of it as every time I change gear lube it's always a Charcoal Gray. Also I would expect a little break-in wear with new mating gears. I had looked on-line for a Dana 50 gear lube specification but didn't find anything.
