Welcome to the forum! Good question, for on-road, I've used the Off-Road setting on rough pavement, seems it may have a little more cushion. I think the 3 different settings would be more significant off road where your utilizing increased shock travel.What’s the softest/ cushiest ride setting for the Braptor?
Thanks.. yes on road is what I’m asking about, good clarity.Welcome to the forum! Good question, for on-road, I've used the Off-Road setting on rough pavement, seems it may have a little more cushion. I think the 3 different settings would be more significant off road where your utilizing increased shock travel.
Thank you. Agree and did 34 psi today and find a difference. Also found off road setting was pretty cushy today as well (sort of). Thanks for the recommendationTo me, NORMAL seems to provide the softest on-road driving.
You should also reduce your tire pressure a bit - I am running 34 PSI all around and it’s a significantly better ride experience than the recommended 39 PSI.
