SwitchPath™ Exhausts for Ford Bronco Raptor - By AWE
"A true-dual, valved catback built to get buck. Premium, robust materials, clearance-gaining design, and a smooth, aggressive soundtrack all courtesy of SwitchPath™. Sign up to be notified when it's ready for lift-off right this way: https://bit.ly/3MGuCEZ"
Ready to Buck: SwitchPath™ Exhaust for the Bronco Raptor​
"Presenting the AWE SwitchPath™ Exhaust for the Ford Bronco Raptor."
"Overview:
- 50-state emissions-compliant dual 3” catback exhaust
- Engineered to crawl (or jump) with best-in-class clearance on even the most aggressive departure angles, providing more clearance than factory
- OE, tier 1 valves ensure 100% factory operation via programmable interior button and throttle input
- Bespoke SwitchPath™ muffler provides dual soundtracks: close the valve for maximum comfort on the highway (cold-starts, as well, if needed), and leave it open any other time for a good time
- Tailored X-pipe smooths the EcoBoost motor of rasp
- Dyno-verified max gains of 1 hp and 9 lb-ft of torque at the wheels
- BashGuard™ features dual .125” thick reinforced stainless ring on the outlet, built for bashing
- Features locking collars for exhaust hangers to prevent movement
- Handcrafted from CNC mandrel-bent, U.S.-sourced .065”-wall T304L stainless steel
- Included additional valve motor and simulator plate to keep the ECU happy
- Less is more: clean, straight-through design for maximum performance and tone
- Proudly engineered, designed, and manufactured in-house, in the USA
- Pure bolt-on, no-cutting required
- Perfect Fitment Guarantee
- AWE No CEL Guarantee
- Lifetime warranty"
AWE SwitchPath™ Exhaust for the Ford Bronco Raptor​
"Overview and sound sampling in one video with driving modes notated throughout.
Part I: Sara gives the rundown on the SwitchPath™ Exhaust for the Braptor
Part II: The raw sounds of SwitchPath™ for the Braptor (important note: due to the high flow of our design, the valve's primary point is to allow maximum cabin comfort when on the highway or when starting cold and volume is a concern)"
AWE Dyno test results copied from AWE web site, as expected not a big gain in HP or Torque, but there appears to be a consistent gain across the entire RPM operating range.
Source:
Available at Lethal Performance:
Uhmmm, we need a review!!!!!!!!
We just filmed the installation sound clips on Friday. They should be edited and published sometime this week. We'll be filming the review in the next day or so as well. The system sounds awesome! AWE did an phenomenal job with it.
omg seriously??? i want one!!!!
Your video Overview, Install, and Sound clips video is now posted in our Video forum!
