I start using Midland MXT275 and GTX handheld when I start doing offroading and overland about 5 years ago. but found Midland was lack of functions and limited use on custom settings. The GTX battery sucks, can't less for full day use.
Two years ago I change to Wouxun KG-X20G 20W fix mount, and Baofeng GM15 pro 8W handheld. Both are excellent with long range and a lot more flexible on repeater and frequencies mode.
KG-X20G can monitor two channels at the same time, is great to have when we have two separated group wheeling at the same time with different channels.
GM15 battery is excellent as well, fully day of use without any problem, also built in USB C charging port. no docking needed like my old midland GTX.
both can use frequencies mode, can be dial in with selected frequencies not limited in channels.
FYI, license is require to operate GMRS radio. Is easy and cheap to get. I believe is $35 for 10 years and you will get a call sign along with the license
