Anyone seen this on rear shocks and inner tie rod boot?
I am on my second 2023 Bronco Raptor. The first one had the same problem with the crumpled rear shock boot. The dealer Replaced it under warrant and there was no more problem. Till the crash and fire at 8,000 km 5,000 mile.
The second Bronco Raptor had the same problem with both rear shock boots. The dealer replaced them. When they delivered it back to me I looked underneath and one of the rear shock boots was all crumpled up. (brand new assembly)
I am currently having my dealer doing an investigation with hotline and Ford Engineers to find out what the cure is.
It will be ok period of time and then tear and fill with snow ice mud and sand.
I can see a table of engineers sitting around a table saying yup that's OK
And a table of mechanics in the next room saying Hell no that's not going to work.
Honestly they should just remove the boots. No other raptor model comes from ford with them, and nearly all good shock brands (fox king etc) don’t sell shock boots on their stuff.
Crawled under the truck today to inspect for damage after pinning a big tree branch up between exhaust, driveline and the body pan. Fortunately it didn’t impact anything soft. But after inspecting everything I found….
The connection of the inner tie rod boot and the steering rack appears to be weeping a little oil on both sides. Should I be concerned or is this normal?
And the rear shock boot looks pretty mangled. Thoughts?
My new 2023 has the wrinkled up boot on both sides. So what is one to do? I read somewhere this is normal and don't worry about it but it sounds like many of you have had them replaced? My thought is to run with it a year or two and then get replaced? I don't know?
I had mine replaced and both boots are bunching again. I really don’t think it’s a problem as most (all?) after market shocks are bootless.
If it bothers you talk to your dealer, but they’ll be bunched again quickly if you’re extending the shocks. FWIW
Without boots, the shock shafts can get pitted from debris, leading to early failure of the seals. Of course filling them up with road salt, ice or sand wouldn’t be good either. It’s good to have the boots for longevity… if they aren’t damaged.
Old style shock absorbers were cheap to replace and even though most did come with shock boots or covers- if they failed a seal- no big deal. These are much more complicated and once you compromise that seal, you lose pressure and fluid and all the functionality of the shock becomes less effective. Ofc course these aren’t cheap to replace.
In the short term I am not really worried about the shock or boot. The boot will fail and fill with sand , mud and road salts.
I would love to know if this is just a 2023 problem? Have a 2024s have the same problem?
I have my Ford Service Department to do an investigation about the problem.
Ford Motor Company and Fox Shocks pay huge money to Engineers and Mechanics just to THINK SHIT UP. I am not going to cut the boot off or modify it in any way. I am going to wait for an answer from the people that get payed the big bucks. I will keep pushing till I get am answer that works.
It really does not bother me, I was extending them pretty good in Colorado a few weeks back. I go to Moab every year and will put the shocks through a good workout. This is not my daily driver so I don't drive it in the winter so I keep all the salt and road grime off of it so this should extend the life of the shocks.
I had a F150 Raptor owner tell me these shocks need rebuilt at 60K. Is that accurate or will most run much longer than 60K? Do you have to send in to Fox? What does this cost? I have never had this high end of a vehicle so I am clueless on these high end shocks.
with boots you are trapping in moisture and fine dust that can still make its way in. Boots are very uncommon on shocks, outside of rancho I guess.
