Obiwan1
Hello everyone,
Hope you are all doing awesome. Thought I would check in with the group to confirm a couple things.
I’m gearing up to do a 2” spring lift. Hyperco 2” standard rate fronts and 2” HD rears as my slide, rear armor case, and gear mean that I currently sit level all around.
My understanding is the HD hyperco’s are rated for around 250 or so additional pounds and that the 2” lift is measured unloaded? So curious if anyone is running this combination, what their thoughts are, and if the HD are the right springs for the rear.
Goal is to run 38 or 39’s (tire manufacturer tire height dependent) along with roper aftermarket wheel and offset. 0 = poke and 18= inboard is my understanding.
So my questions are:
-Is that spring combination recommended. Any issues with the rear Hd springs in terms of drivability, harshness, and actual lift loaded?
-Did any of you doing the rear 2” lift need to replace the track bar with an adjustable version? I can’t find clear answers on this.
-Presuming VDM reset/calibration will be required.
Thanks everyone in advance!!
