irishkpo
Who has installed one in their Raptor?
I ask since I haven't found many options that don't require the permanent removal of that additional factory crossbrace. Units that I am aware of are listed below. Plenty of manufacturers make units that I like but so far it looks like only JCR offroad makes one that fits with the current factory brace still installed.
If anyone has pics they can share of their installs, I'd love to see them.
Thanks,
JCR Unit - compatible with brace - It is the only one that I have found so far that let's you keep the factory brace. Worried about my J-Top wearing between the brace and the panel though. May have to add some soft edge protection on the sides of the Molle panel so that it doesn't cut through the J-Top over time.
DV8 - Not compatible. Require the permanent removal of the factory brace, but makes a reasonably priced one that even has a nice long grab handle for those in the rear. I actually really like this unit.
ADD - Not compatible. A lot like the DV8 above butt, requires the permanent removal of the factory brace and doesn't have a grab handle.
Buckle Up - Not sure - Don't care for the design though.
Turn Off-Road - Not Sure again - Don't care for the side to side design again.
Thanks,
Bronco Overhead MOLLE Panel | 6th Gen (21+)
Jeep Bumpers, Sliders, Armor, & Accessories | #BuiltForWhatever
www.jcroffroad.com
2021-2024 Ford Bronco | Overhead Molle Panel
Our Bronco overhead molle panel offers versatile storage with its molle pattern to mount gear like bags, phone/tablet holders, and more for overland adventures. This easy to install panel utilizes factory mounts to stay secure on trails and provides a grab handle plus slots to mount lights and...
dv8offroad.com
2021-2023 Ford Bronco Overhead Molle Panels
Our 6th Gen Bronco Overhead Molle Panels are designed with utility and style in mind. With one panel spanning between the driver & passenger seats and a perpendicular panel running behind them; your gear is readily accessible while seated. Made in the USA.
www.addictivedesertdesigns.com
Buckle Up Off-Road Overhead Molle Panel Organizer for 2021+ Ford Bronc
STYLE Buckle Up Off-Road Overhead Molle Panel Organizer designed for the 2021+ Ford Bronco 4dr offers a range of storage possibilities and convenient access to your equipment. With this well-thought-out arrangement, your items are easily accessible even when you're seated comfortably. The Molle...
buckleupoffroad.com
2021+ Ford Bronco Overhead Molle Panel Storage Kit
IA1-OH2021+ Bronco Overhead Molle Panel Turn Offroad’s Overhead Molle Panels provide Bronco owners with endless mounting opportunities for trail gear and accessories. Our overhead panels expand useable storage space and don’t interfere with top removal or side curtain airbag deployment. They are...
turnoffroad.com
