Rear Speaker Pods
Schave
Kentucky
Has anyone heard anything more on upgraded speaker pods for our Raptors? Looking to move up to 6.5" co-axials in the rear.....and I'm sure I'm not the only one!!
Nope, you're not the only one! I would be interested in upgrading the stereo as well. It will be interesting to see what others are doing.
Im not sure if these pods will fit our Raptors as there is not as much space available with the cross brace on the roll bar
I can confirm that they will NOT fit. I had mine in for an upgrade at a local shop. They have almost completed the install, but realized the rear pods wouldn't fit with the cross bar support . They did ask if they could remove it...............
So, I'll be needing some just for our Raptors ASAP. They went ahead and dropped in an upgraded set of 4" for now, but that won't do once the top comes off in the Spring.
Which ones did you try?
MTI just released theirs finally, but the empty pods are $400. Seams a bit pricey to me but its the only thing on the market at the moment
wish they didnt look like a 1980s build where you still use the grills that come with the speaker. Too bad tney couldnt integrate a removeable cover like oem.
I have an extra set of MTI Raptor pods new in the box. I love the set that I installed. They are a nice fit and sound great.
I will sell my extra set for $225 + shipping from 23226. Please let me know if you want them.
Do these make a substantial difference? Without making changes in Forscan it was my understanding that full range signal wasn’t sent to the rear speakers. Did you add an amp?
Sorry for the delay. So yes I removed the B&O amp and installed a JL VXI. It sounds absolutely amazing.
I've seen two but cannot confirm Raptor Fit.
There's this one sold a crutchfield: https://www.crutchfield.com/p_327BRB65U/SSV-Works-BR-B65U-6-5-Rear.html
There is also one sold by Mabett on Amazon, but is currently out of stock. Mabett is the one I want to try so when its in stock I'll let you know. Amazon product ASIN B0BLYMPH1R
I tried the Mabett this morning and they DO NOT fit the Braptor. I saw on this thread that MTI work so will go that route. Note if you go MTI, you need to buy speakers with front grill
Did you need to order a harness to make the JL amp work with the OEM stereo? I had read on one of the posts that the rear PODs are not powered by an amp but only the OEM stereo. I was trying to figure out how to amp up the PODs. I just ordered the MTI. Appreciate any insights on your upgrade.
  • Like
Reactions: OFP
Thinking about ordering the MTIs. Any feedback? Have they even arrived yet?
Yes, MTI arrived and installed. Perfect fit but make sure you order speakers with the front grill. I ordered the speakers on the MTI website as it gives you several options along with the MTI Pods. I went with the JL as that is what I upgraded all other speakers to.
  • Like
Reactions: OFP
The MTI worked great on my Raptor too. If you have the non-B&O system, I recommend kicker cs series and they’re very efficient for the low power head unit. And don’t forget to use Forscan to open up the sound.
If you’ve got the B&O, you can upgrade to something a little better and no need to use forscan.
ANn pics of the MTI setup?
Welcome to BroncoRaptor.com! 🍻
MTI Accoustics Bronco Raptor
