Are we in for a treat? With numbers like this.. The Raptor has to beat this! 0-60 in 4.9
djc007x
Washington, DC
Hennessey VelociRaptor 400 Bronco​
SPECIFICATIONS: VELOCIRAPTOR 400 BRONCO​
POWER:​
• 411 bhp @ 4,400 rpm
• 603 lb-ft torque @ 3,200 rpm
PERFORMANCE:​
• 0-60 mph: 4.9 seconds
That would be great but no. We won't be able to get sub 5 second 0-60 times. That Hennessey has 603 lb-ft of torque.
The 2021 F-150 Raptor weighs about the same as ours but has 450 hp and 510 lb-ft of torque and manages 0-60 in about 5.5 seconds on 35" tires.
I suspect with our 37" tires and less "power", our 0-60 times will be in the 5.8 to 5.9 range.
Edit: I'd love to be wrong :cool:
Hennessey has a lesser engine ..2.7 Raptor tune should beat it
Oh, you meant after modifying the engine/programming. Perhaps, but I won't be doing that to an 80k vehicle and I suspect I'm in the majority.
I will applaud and cheer on those that are part of the "we" that will be doing that.
Since our Raptors already have an upgraded exhaust, according to that info all we need is a tune, CAI and better cooler..........you first. :)
I'm not saying you couldn't engineer a way to produce that torque with a Raptor, just that Ford won't meet that spec out of the factory. Hell, I'll be happy if it hits the street with 450+ lb-ft...
The Explorer ST provides an interesting comparison. Same engine as Raptor, 1000 lbs lighter, and even with some incredible tunings (up to 657HP) never really breaks the 5-second mark. Hennessey must have worked some black magic on that Badlands.
Yeah, his site lists very little but he must have done more. Guys are getting crazy numbers running E85 but that's not how Hennessey does it.
Do you guys understand the process? A Velociraptor 400 is a fully factory warranty and approved Bronco, yes it weighs 1000 pounds less that a Raptor, has a weaker engine but everyone is saying it's not possible the Raptor is Faster or will come close..
I just can't see Ford putting out a product that is less than what's currently available to all Bronco Owners
True Story
How fast do people want to go in a flying brick? There is 0 aerodynamics to help us. I just want to be able to merge on the highway at a acceptable speed
If I want to drag race I'll use my Z06. You're not going to get good 0 - 60 times on dirt/trails anyway.
