Thoughts on Rock Crawling and 39 to 40 inch tires and bead locks
pkdrew
Atlanta
2024 Bronco Raptor
2024 Ford F350
I’ve got a 2024 Bronco Raptor that I wheel pretty seriously. I’ve upgraded the Steering rods (FMI) and the steering rack (BroncBuster steering rack upgrade kit) and have lifted it with the Eibach Pro Bronco Raptor Lift. Also have completely armored the underside with Next Venture Motorsports. I’m running 12.50x37x17 Baja Boss M/T on Icon Rebound Pro rims (the ones with pins behind the bead).
However, I’m still pushing the limits on this rig and headed to some serious rock crawling ventures including the Rubicon. I trailer the bronco out and back so not concerned with Street Legality but I don’t want to end up destroying some other suspension part because I’ve pushed it to far.
What I’m now considering is putting true Bead Locks from KMC with more offset on the rig and either 39x13.5x17 KM3 tires or maybe even 40x13.50x17 Baja pro tires. Any thoughts or experience on whether the CV and outer axles can handle this? The only steering rack issues I’ve experienced on my current setup so far was some overheating on some hard core trails in the Palo Duro Canyon in Texas last summer. Once it cooled off it was fine.
I just need a bit more tire clearance and a bit more room for my fenders on canyons with extreme off camber and rocks/walls next to me. I’ve already ripped done drivers fenders off once.
Thanks in advance for any experience and input here.
Hi, I have a similar setup on my 2023 BRaptor. Same Eibach springs, Next Venture Motorsports sliders and skids and the 74Weld steering rack with the FSI tie rods. I also wheel mine pretty hard and have been very glad for the addition of an upgraded rear bumper. I went with the ADD Bomber rear bumper and I'm very happy with it. I enjoy wheeling at Sand Hollow park in Utah and many of those obstacles have steep descents with vertical drops that are guaranteed to destroy the factory rear bumper. I'm currently on 39" Goodrich KM3's and have no clearance issues. I use about 15 psi when wheeling hard trails with the Method Wheels internal bead securing ribs. My main issue so far on hard trails is the steering. Once the front locker is engaged, and your on any type of difficult terrain, it becomes almost impossible to turn the steering wheel. I've had to really limit using that locker unless it's absolutely necessary. And then I have to figure out how to make the turn at the top that many of the obstacles require. I asked PSC Motorsports if they had any plans to make a hydro assist system for the Broncos with our IFS front suspension and they said it was something they were looking at and it was "currently on the whiteboard". If they ever do offer one, I think I would want to be near the front of the line to get one. I'm also planning to do the Rubicon and if you ever find yourself in southern CA send me a message and I'll be happy to take you on some of the local trails!
Tim I am looking into the Mud Terrain T/A KM339 X13.50R17
I have the 7x8.5 rims Beadlock capable. I know I will have to lift the braptor.
two questions:
1) did you keep your stock rims?
2) any clearance problem for the 39" spare? on the old or new bumper.
I went with the Method 703 Raw Machined MR70378516300 rim. I liked the raw aluminum look since anything with paint or powder coat really shows the scratches and scars. Also the internal locking ribs for the bead are legal for the street here in CA. The 39" spare did require a kit to extend the center brake light higher so it remained visible.
Thanks, it looks sharp. What size rims did you use?
Pretty sure there 17"x8.5". They've stood up very well to all my abuse for the last six months!
I've checked out the eibachs. From things I have read being they lift 2.6" some folks have destroyed their lower control arms because the valving doesnt align with after market shocks and it deadblows the FOX shocks. But I also know that is from folks going balls to the wall jumping. So i havent completely lost interest in doing this myself and imagine it would be ok crawling around. How does it ride in the different modes, surely it is harder even in baja?
How are the wheels for cleaning ?,
The OEM Beadlocks are difficult to clean.Also they are easy to nick up off road.
I havent had any problems with the suspension so far and I've had the springs installed for about 6 months. I have modified my truck to make it better at rock crawling and do not do much of the high speed Baja style stuff. It's very difficult to describe how the spring change affected the ride of the truck since I did several things at once. The springs added about 2.75" up front and 1.5" in the back (love the new leveled look) and the tire change added another inch to the ride height for a total gain up front measured at 3.5" and 1.75" in the rear. If anything, the ride is a little softer now, but the truck does not handle as well on pavement. With the CG raised way up like that and the switch to a mud terrain tire it just does not turn or stop as well on pavement as it did stock. For me this was an acceptable trade off since I gained a ton of capability on very hard trails which was what I wanted. I've done a bunch of trails at Sand Hollow state park and most of them end with a high speed blast back to the staging area on the dunes. I have found myself slightly in the air after topping a steep dune with a little too much speed. So far no damage!
To 95BK9, these wheels are MUCH easier to clean. If you look at the picture you'll see that they are a much simpler design than OEM without all the fake beadlock ring stuff.
@timhuch - I missed this chain sorry I'm so slow responding. I do plan to come out west and would love to do Sand Hollow. My steering rack is what I'm worried about the most. Haven't found any way to upgrade that any further either let me know if the options you are looking at come available. I trailer the rig to most trails unless local so I don't put many highway miles on it anyway. Just worried about braking something bad deep in the woods. I was looking at the 39 inch KM3 but the specs say min wheel width of 9 inches and mine are 17x8.5. Oddly the 40 inch M/T claim 8.5 is fine. The KM3 are really 38.5 inches in diameter and the M/T 40s are closer to true 40 so about an 1.5 difference which adds even more stress. I keep reading that I'm gonna need new axles, CV Joints, etc. I'm not certain if that's from stress and wear from miles and miles on the highway with extra unsprung weight or from the actual wheeling in the mud and rocks.
Your OEM Bronco Raptor axles are the same as used on Ford Performance 4600 race trucks.
Check out @22broncoraptor Godzilla build with 40's with OEM axles but did upgrade to the 10R80 transmission due to the engine swap, not the 40's.
Nice thanks !!
I LOVE 'em; way to go.. I HATE the black/gray-painted light-alloy wheels so popular now.
I’m taking it to the shop today to have the 40s mounted and see how things look. Then I’ll make the final call. Since I out very little street miles on this Braptor and I’ve upgraded the steering components and I’m careful with my front lockers hopefully the rig will handle the load.
Pictures please, want to see those 40's! I'm holding off on the 40" tires for a while longer. Not because I'm worried about breaking axels/CV joints, etc, but because the larger tires are raising the gear ratio of the truck and reducing low speed torque/power. I've been looking for a set of gears in around the 5:33 range (original is 4:77) and have got my name on the list at 74Wield as an interested customer if they ever release portals for the BRaptor but so far no good solutions for lowering the gearing to restore the original performance. Be interested in how your truck feels after moving up to 40's.
Tim
Tim, I had them put them on the truck then took them off without taking pictures. I'm so sorry. I could just tell that the jump from 37 t0 40 was much more pronounced than I anticipated and for what I do with this rig it was going to be too big a risk for too little return. My plans are to tackle Sand Hollow, Moab and the Rubicon in the next 12 months and for 1.5 inches of extra clearance, the downside is too high for me. I need reliability in the back country and it's the steering rack I'm worried most about. It won't break (I've secured that) but the motor is already pushing its limits and I can't seem to find a better option for it. Plus I need the maneuverablity on the rocks and comments are rampant about losing that with 40s on that rack. In the end, I decided to stay with my sticky mickeys at 37/12.50/17 for now. I have plenty of armor to withstand dragging and scraping and pounding down below. And a great winch. And friends on the trail with me. It's not about looks for me it's about back country performance.
Be interesting to follow this thread and see what feedback you get. I did the Rubicon last month stock in my '24 Bronco Raptor. The only rock crawling mod on mine was FMI shock skids. Everything did great except for, (i) the running boards, which got bent upwards pretty good but also saved the rock rails and body. I'd say your choice on removing or not. If you leave them they will get bent and take damage; and (ii) the fenders got chewed up pretty good.
That was again on stock 37x12.50x17 BFG KO2's and stock non bead locked wheels. Went to 12 PSI and had no issues.
My personal takeaway was pop the fenders off and get some fender clips for cheap from IAG (can find them on Amazon)...... OR do what you're gonna do!!! :)
I have since added FMI diff skid and rear lower arm skids. I did run a trailer ball with a 3" drop as well. Did not remove or lower air in rear tire and the hitch did it's job taking scrapes.....
Looks like a great time! Can I ask who makes the wench you have mounted? Also looks like it has a front camera installed in it so you don't loose sight lines? Thanks Chris
It's the Warn Zeon 10-S from Ford Performance with their standard mount. They had a sale over Christmas and I was able to get it installed by them out the door for ~$1350.
I did the camera relocation later on. I took the front license plate bracket that came with the winch and bucked it up to my liking with an angle grinder and cut off wheel, then bought a new camera for ~$70. Then I unhooked the camera under the hood and ran the line out to the new one. Seems to work well. Didn't want the hole in my grill hence the new purchase :)
I still need to relocate my front sensors..... one of these days I'll get to it.
