- Dec 3, 2022
- 516
- 965
- Ford Bronco Raptor
- Current Ride #2
- Jeep Cherokee Trailhawk
- First Responder
- 27 yrs SAR, Wilderness EMT, retired
Observations ...
Biggest observation: not a BRaptor; not interested.
Exactly!!! Your VIN decoder is incorrectBiggest observation: not a BRaptor; not interested.
I’m confused, your VIN with 1FMEE5D is not a Raptor, Your sticker says it’s a BigBend. That would seem to be reading correctly at that point. it would need to be 1FMEE5J to be a Raptor. Where’s the issue? I’m curious.Exactly!!! Your VIN decoder is incorrect
Correct … but your decoder ring shows that Raptors have PLA8****I’m confused, your VIN with 1FMEE5D is not a Raptor, Your sticker says it’s a BigBend. That would seem to be reading correctly at that point. it would need to be 1FMEE5J to be a Raptor. Where’s the issue? I’m curious.
Not my decoder ring, but the two “decoder rings” above indicate that either:Correct … but your decoder ring shows that Raptors have PLA8****
Congratulations, you're in the same "B" boat as me. I'm currently 3/6 also. What color are you?Any guesses on the VIN and build. 1FMEE5JR5PLB00780 Last projected build date from Ford: March 6th.
Too many zeros. I wish my paycheck had that problem.Not my decoder ring, but the two “decoder rings” above indicate that either:
1) 2023 Broncos will be between A80000 and C99999. This of course applies to all Broncos including Raptors. Pretty clear and hard to argue with.
2) That Raptors will START with A800001. I’ll assume this is a Typo and included one too many “0”s. While 2023 Raptors could potentially start with A80001, Its also somewhat problematic as they’re not guaranteed to start at that number, like 2022s did actually start at A50000 (which ran sequentially somewhere past A52800 with no apparent standard Broncos inserted in that series). However other than the typo, nothing technically wrong with this decoder ring either, unless one makes the assumption they will absolutely begin at A80000 and run sequentially like 2022.
My curiosity is satisfied, thanks!
Dude … you’re saying raptors last 8 of the VIN start with PLA8 which this one does and it is not a raptor … vehicles are not built in sequential VIN order and not all PLA8**** are raptors ….
Dude, you are OCD. I never said that; that is what you ASSUMED. As JohnGalt said: 2023 Broncos will be between A80001 and C99999. This of course applies to all Broncos including Raptors. Pretty clear and hard to argue with.Dude … you’re saying raptors last 8 of the VIN start with PLA8 which this one does and it is not a raptor … vehicles are not built in sequential VIN order and not all PLA8**** are raptors ….
Azure GreyCongratulations, you're in the same "B" boat as me. I'm currently 3/6 also. What color are you?
Bump #6.
Did your order get assigned to a plant last week?Congratulations, you're in the same "B" boat as me. I'm currently 3/6 also. What color are you?
