Rubicon Trail
Not that Ford possibly might make a mistake in their parts catalog, but that bracket for the Raptor in the diagram looks nothing like the bracket on my truck.
the leading bracket on the passenger side is actually pretty well protected as skid plates run close by and appear a little lower than the bracket bottom.
the driver side is more exposed as the muffler runs beside it. My drivers side is already a little ground on the bottom.
that said, the brackets are pretty stout, nicely
ramped and hang well below the arm pivot. Doesn’t appear to be any easy attachment point to add a skid. It would have been nice if they boxed in some of the bottom, but not sure if that would impact ease of assembly/disassembly or not.
While Kevin clearly hit his passenger bracket, was probably more hung up on his skids than the lower arm brackets. It looked like the passenger bracket was clear and the truck was hung up pivoting on the underbody skids
Okay so you made me crawl back under it and now I see what you mean... I'd still like to have the skid plate for the price we pay anyway.
Badlands (Driver's Side?)
Bronco Raptor (Driver's Side)
I can't see what Kevin was hung up from the video angle, but he clearly needed a winch pull. As you noted, the bracket clearly took a strike. They complained about the same bracket on the Chinaman. I've struck both of mine in the past, but slid past the step I was climbing.
Other than the rear diff, said bracket is the lowest hanging fruit; especially for the breakover angle. The muffler [6] sits higher than the bracket [2]. I used to lament that 33" tires didn't give me enough clearance. Now with 37" tires (36.5"), I'm likely to say the same thing. Note that the purple 2dr Jeep in the video was on 40s.
My RCI sliders [1] mount to the frame [5] so I don't have a lot of room for a bracket [2] modification. That said, there may be some room to weld a bracket extension [3] and a skid [4]. Or just use my winch on the front.
The 🌶️ Raptor looks like she needs a bath. :ROFLMAO: Every time I wash her she just gets dirty again. :unsure:
Here is another (parts catalog) view of the BR bracket. It looks pretty close to real life.
I’ll be putting those sliders on soon hopefully. Looking at something like JCR skids for Bronco, there is a bolt above the pivot in the bracket, but no easy attachment to the frame (even before sliders). There’s no bolt hole and no easy access to place a nut in the frame if you’re willing to drill.
I wonder if I could weld a little wheel in front of the brackets and just roll over stuff? 🤪🤪
The Bronco Raptor bracket doesn't hang lower, just a more abrupt angle so rather than sliding over obstacles it appears to need to be lifted over. Doesn't hang any lower.
Badlands has better angle for sliding and is very close to same distance from frame but definitely a different bracket.
Welded mini slider part number.. maybe "50425 AC" inside of slider is "088 23"
In this later pic above of the Badlands bracket, is now part of the frame mounted LOD Detroyer frame mounted Rock Sliders. Wife wanted steps, so we went with frame mounted rock slider steps.
I was also thinking rollers, just Hit it and roll over it. Hmm, I don't have any off-road experience.. ya don't listen to me. :giggle:
Supposedly my RCI sliders will ship tomorrow. I assume you installed yourself, any tips / tricks someone lazy and easily frustrated like me should be aware of in the install?
Probably most concerned on what I’ll need to do related to the gas tank and it’s skid.
TIA for any info
TIA for any info
As a precaution, low fuel level thereby lightening the gas tank. On the LOD frame mounts, the rear mount was inserted between the frame and gas tank skid on the back two outside skid bolts to frame. I ended up loosening all the gas tank skid bolts in order to gain enough clearance. With low fuel, there didn't seem to be much stress on the skid bolts holding the gas tank and I could easily push the skid tank combo upward if needed. Guessing you may need to do similiar with the RCI frame mounts.
Also, I used a couple bottle jacks to hold (push) the mount in place against the frame while I bolted the mount to the frame.
Use caution as these sliders are heavy, would be easy to slip and end up with a slider rotating and contacting the body.
TIA for any info
I think I did a write-up back in May. The pinch seam covers were the tricky part; cut to length. No issues with the removal of the OEM parts. No issues with installing the RCI sliders. I did not drain my full gas tank prior to the install. A ratchet wrench was helpful in the tight spots.
TIA for any info
Also preparation of the frame, the nasty dirty part. LOD recommended the grinding the excess weld beads, on the bottom of the frame in the areas where the brackets will mount, so that the bottom of the frame is perfectly flat so the brackets fit flush against the bottom of the frame. Use a hand grinder with flap disk but beware there will be grinding dust everywhere. Eye protection, gloves, and face mask are a must. After grinding I painted with Blacktop epoxy chassis paint and allowed to dry at least 24 hours. I remember now that is why I dropped the gas tank skid lower to get the grinding disk between the skid plate mounting tabs and frame.
Of course, check the RCI install instructions first.
Tools I used:
Amazon product ASIN B00RZV20CS60 Grit, I went thru 3 of these disks in this 10 pack.
Amazon product ASIN B01D0HIIJE
Thanks, I just went back and found your write up on the pinch seam covers.
I’m guessing that you had to trim the covers to work around the two bolts on seam line behind the front wheel well.
I saw the JCR covers bolted down the covers with these bolts on a regular 4 Dr Bronco.
Do you know if these are different on the BRaptor ( @TurboS may know as he has both) and that’s why the trimming was necessary?
The wife's white Bronco Badlands vs. CO Raptor. I added Ford accessories rocker panel trail armor to her Badlands so I took pics from below. It appears to me that the front lower fender bolts are in the same location but the Raptor composite fender has the extra support piece. @JohnGalt Is this helpful/what you needed for comparison?
Thank you, this was very helpful! With your pics and Chilipepper‘s photo (below), it looks like the support for the front fender is the culprit. It looks like he tucked the seam cover into the gap visible in your photo or may have gotten the rearmost bolt through the seam cover. i just can’t see it clearly enough.
Well, at least I know why it needs trimming and leaning toward just tucking it in vs trying to thread the bolt through as I think it’s going to affect the paint.
… and it looks pretty straightforward
Now I’m thinking does the marginal improvement in looks offset the fact that it creates a place for water and dirt to fester between the seam and the cover?
thanks again, all
thanks again, all
Do those metal pinch weld covers provide any mechanical advantage such as providing additional support in case the frame mounted slider bracket would flex enough to contact the pinch weld?
I choose to get these lower panel covers that offer full stone impingement protection. Easiest to install before your frame mounted sliders. For our Bronco Raptors, there will need to be some of the very front edge cut off as the lower fender on our Raptor's is shorter, noticable in my photo's above. I'm planning to order and install on my Bronco Raptor this winter.
We think they provide a "finished" look. The are stuck on with 3m body molding tape, continous seal along outside (top) edge, front, and back edge. The raised section to clear our OEM rock rail mounts to the pinch weld allow ventilation. These do not fit tight against the paint, only the 3m molding tape contacts the paint.
those look like they’ll do the trick! I suppose the metal covers would provide additional protection in the event something unexpected happened, but probably not a lot of protection.
im just going to make an install / no install decision at the last minute. Didn’t really think the seam covers all the way through. Bought them since it seemed like all the other kids had them!
thanks again, all
Well, if you're worried about dirt, rain or snow, then keep it parked in the garage or visit a car wash. 🤣
The 'edge' of the pinch seam cover is a bigger collector of mud. Wash it good.
