Ford Performance Air/Oil Separator DIY installation
I am taking my Bronco Raptor into the dealer tomorrow for an oil change and to look at an issue where the front camera spray nozzle leaks my entire tank of wiper fluid after installing my winch. While I'm there, I will inquire again about an update for the FP AOS fix. My dealer has not contacted me with any information about it since I initially requested it. They have just said that FP is not responding to them so far. I don't expect that to change.
I haven't had them do the zip tie fix yet. I tried to do it myself, but I couldn't figure out exactly where to tie it and how to mount myself over the engine up that high to properly leverage it. So I will ask them to either do this or whatever the current workaround is that FP recommends.
What's the status of everyone else in this boat?
  • Did you have the FP AOS uninstalled?
  • Did you get the zip tie fix (how's it working?)?
  • Or have you just let it keep rubbing?
it is not too difficult. pull the canistar up off the metal bracket push to the drivers side like an inch just passed the hose it hits on the botton and just zip tie it there. holding it towards drivers side. Yes and still no fix. Ford already reimburded me full amount but still no fix but when they do should get everything free to fix it.
OK, I just heard back from my dealer
there isnt anything we can do about the oil seperator
So, they aren't hearing anything new from FP. Not even to do the zip tie workaround, or a new temp resolution. The guidance now appears to be just leave it there. I had asked the dealer if they might need to remove that one AOS and leave the other, but they aren't opting for that option either.
They are changing my oil today, so I assume they are at least cleaning the catch cans. But after just under 3K miles, I doubt there's much there.
The zip tie deal is just the logical thing to do at this point. If you leave canister on the bracket or even in that same spot it still gets sandwiched between a hose and hood which will lead to further damage, you have to move it and hold it to drivers side with zip ties. Ford at some point will have to come out with a new bracket and hoses for that particular canister. The dealer I went to twice wasnt too bright and thought they fixed it, so the second time using a small rotten stick in the steed of plastigage to prove it was still hitting they finally wrote down that is needs to be redesigned so i can get it warrantied or whatever. Since I was reimbursed full amount and eventually when they have a fix will be on that list for new parts. You essentially will be getting it for free and the 600$ is to help with repairing hood/paint etc.
I ordered from Ford Accessories at the link (in this post). How do you go about requesting a refund? Did you do it through your local parts dealer?
I believe I went through ford performance support. I ordered mine through CJPony so it took a bit longer for ford to reimurse them and them to me. but you do need (for whatever reason) get a dealership to say "yeah it is flawed".
try this email
fwrnty@ford.com​
Update on my comments on the Ford Oil Separator.
After I discovered the damage to my Raptor’s hood and the top of one of the oil separators, I decided to examine the problem and design a solution.
It required multiple measurements, cutting, bending, grinding and subsequent painting of the bracket.
I’ve been running it now for 4 months without any further damage, or vacuum leaks.
For those without any fabricating skills, send it back, but for those who can, it was a time consuming task but still very doable.
Good Luck on your own individual solutions.
The hoses are set so how are you bending them, reheating them? It is an easy enough fab job to be honest I just did not want to mess with reconditioning the hoses. Lets see what you did.
Sorry, I didn't take any pictures, and you're correct, it's an easy job for those of us who have done easy jobs before.
And I used a heat gun, very carefully, and massaged the hoses a little, really doesn't take much to get them to fit.
I experimented on one of the old hoses first to see how much heat it would take.
Having worked with old time plumbers, who knew how to work lead, I came to understand that if you put a torch on a lead bend, it will disappear faster than an OREO Cookie at a weight watchers convention. The same is true of those hoses.
The time spent was in measuring the hood to the oil separator top, the stock unit really sits way to close to the hood.
I eventually used Play Dough to measure the clearance. It was kind of like using Plastigauge when I was measuring bearing clearances.
Hello all... I just received an email from Ford Performance Warranty advising that a new Air/Oil Separator has been created for our vehicles. This is due to the hood rubbing issue with the model that they sold until early this year. They advised that they will be sending replacement units in October to those that purchased the older units. If you have not done it yet, contact them at: fwrnty@ford.com and verify purchase & address so they have correct shipping info.
Hello all... I justreceived an email from Ford Performance Warranty advising that a new Air/Oil Separator has been created for our vehicles. This is due to the hood rubbing issue with the model that they sold until early this year. They advised that they will be sending replacement units in October to those that purchased the older units. If you have not done it yet, contact them at: fwrnty@ford.com and verify purchase & address so they have correct shipping info.
Thank you!
I have forwarded my Ford accessories original email order receipt along with my address to this Ford warranty email address. I promptly received an auto reply that my email has been received and will be reviewed. It's a gratifying feeling of progress. 🤞
Thank you!
I've received a reply from Ford Performance Warranty:
"I have added your information to our file. Once the new kit is released, I will send you the revised components for the kit to improve hood clearance for the air oil separator.
The latest info I have heard for the revision being available is October of this year."
Thanks a lot. I've sent my receipt and my dealer's parts address to them.
I received the same confirmation. It's great to get a quick response from FP (er Ford Racing) after all these months.
So still no updated piece from FP?
Glad you asked, I just went back and searched my email and found I missed this email update from November 19, 2025. Had I seen this email at time of receipt, I would have posted this update below, my bad, I'll watch for further updates.
"I wanted to provide you an update. The kit has been experiencing delays. Right now we are looking at within Q1 of 2026, however we are trying to reduce that time as much as possible working with our suppliers."
Thank you @Epiphany for asking
Thank you for the update. I also was wondering how long this delay might be. I was hoping to get it before February since I have a busy schedule after that.
Yeah we have been waiting a long time. I will be going to King of the Hammers again this year and Ford Performance engineers are there. I will be asking them about it for sure.
January 20, 2026: Revised Kit update from Ford Racing Parts (rebranded Ford Performance) in quotes below.
"I am still waiting on the revised kit, however I anticipate it should be releasing within this Q1 period."
While at KOH this year I spoke with an Ford Performance engineer who contacted the engineer in charge of this project. This is the most current information straight from the source.
So the engineer tells me that they received the new oil separator for the kit but they’re still waiting on two new tubes. The supplier found a leak on some of the 90deg connectors which became a mold issue and they’re trying to sort it out now. So we don’t have an exact ETA. But that is the current status.
Well at least we know they are on it!
